It is currently Fri Jul 18, 2025 6:54 pm
PostPosted: Tue Dec 05, 2006 11:20 am
My build is based on a Gibson AJ. I've used the dimensions for the length, lower & upper bout, and waist that I found on the net. The thing is I haven't found the bracing locations for the back. Is there a "standard" ratio used for the location of the braces on the back? If not, how are the brace locations typically calculated?    nathan c39056.8133101852
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Tue Dec 05, 2006 9:49 pm
    I can't say there is a standard but I use martin's layout
   from the neck joint point
3 3/4
7
10 3/4
14 1/2
   I tried differecnt location , but what I found is the shape is more important than location.
good luck
john hall
